respirologyrc
08.20.2010, 01:35 AM
NO bearing SLOP!!!!
Again no bearing slop, and you can see that the top chassis deck was slightly drilled to accomidate larger spurs. This pic shows my 50T spur with no clearance issues at all. Also you can see how clean and put together it is. You will also not that the holes in the top chassis were used to help hold down the top deck....
The original chassis comes with braces that hold the top deck to the chassis. Well to improve upon this design a larger diamter piece of aluminum tubing was used and adds to the rigidity of the chassis. Here is a pic of the differences in diamter of the braces used. The stock ones are the skinny ones and the fat ones are the improved modifided versions that help tighten up and strengthen the chassis!!! I removed the plate for easy viewing...
