Manne
10.26.2010, 04:39 PM
Looks like I have to get a e-bay account then!
pinkpanda3310, Thanks alot! Can you give me the meassures of the inside of the pinion bearings and the inner and outer size of the other two bearings?
Should we call the outside of the pinion bearings 16mm? or is that some wierd size in inches or something?
Semi Pro, I read your thread before if I remember right, For how long have you driven the truck on 12s?
How many different versions does losi have of their raminator, Lst, XXLst, and lst2 differentials? Wich ones should I stay away from and wich ones comes with alu cups and wich ones has tiNi gears, magic mushrooms, hidden ferraris and other good stuff in them?
Edit:
I think Iīve got it now, they come with non TiNi gears, a plastic cup and outer aluminium housing, so, where are you guys and girls buying alu cups?
Edit2: I found out that the pinion shaft is 8mm ("Big bearings for the pinion, which has an 8mm shaft" http://rc-monster.org/forum/showpost...00&postcount=1 )
So the pinion bearing is 8x16mm... Time to check the bearing size of the Savage Bp pinion
Edit3: .........Bp pinion=8x16...
We might have a go here! But I think I will wait with this whole whing until mike gets some hybrids out again Canīt wait!
