02.07.2011, 12:56 PM
Ok, so if I want to sue the lst2 c hub I have some fixed measurement requirements.
The hub end of the arm has to have a 50mm min outside width, and a max of around 35mm inside width. That is the stock spec for the savage arm. That leaves about 7.7mm of pivot thickness on the outer end of the arm, which is about the min I can see, any less and it would be weak.
On the bulk end of the arm, needs to be a min of 58mm to fit nicely between the stock savvy hinge pin braces. This can be less if necessary as the difference could be made up with shims of some sort.
I have a feeling the hub end arm requirements will be a problem, as all of the truggy arms listed so far are narrower at that end.
The length of 126 is not that big of a deal as the outer holes could be drilled on the truggy arms in the correct location. This may also help with the width issue at that end, judging by the pics the truggy arms get wider closer to the center. Some cutting and trimming/grinding will be required... A drop in solution is likely not to be found.
