GriffinRU
03.12.2006, 04:48 PM
Originally Posted by BrianG
That sounds pretty straightforward. I wouldn't even thought about the timing, but it makes sense once you explain it. I was telling one of the guys at my LHS about what you did and he was pretty interested once I explained it to him a few times (wasn't getting it at first). Have you tried to pull the windings out of the slave motor to save a little bit of weight? Of course, you'd have to be careful not to wreck the hall-effect sensor...
Thank you, I was trying to put it that way ..:)
I ordered from E-Bay horizontally magnetazed neodym rings and will try to build custom sensor feedback. Taking HV4400 motor apart, I think is just waste of time. If you creative then use it as generator to keep your RX power pack happy :)
7XL on 12 cells just slow... and brakes need to be trimmed on TX side
I need to replace it with smaller motor (Hacker C50 14.4 is coming) and ditch 2 speed tranny :) (Personal opinion!)
Artur
P.S. Hey guys do I miss something? I run stock (shimmed) diffs and trashing CVD's... Doesn't sound right or ...
