Preparing for Spring
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
Preparing for Spring - 02.12.2011, 02:30 AM
I did some work on the MMGT:
- The truck has had every last Phillips head screw replaced with a Socket-cap screw.
- I made suspension travel limiters to lower the ground clearance and help with roll-overs. The part list is in the slideshow. They work very well!
- I mounted the Rx on the bottom of the radio box cover and ran the antenna back up through the cover. It's pretty slick looking and it keeps the sand/water out of the Rx. Ignore the fact that the cover is cut in half...that idea never made it to fruition but, sadly, you can't "un-cut" plastic...
- I strengthened the motor mount by using another motor mount. The motor now has 4 screws into it, and 4 more holding it to the chassis mount.
- I replaced the stock POS Z-bend steering link with a custom ball-end linkage. This removed a lot of the slop from the steering.
- Gorilla Snawt was purchased and is used throughout the truck in the center transmission, F/R diff bevel gears, and in the U-joints. The diff bevel gears were difficult because the GS would end up in a ball in the corner of the diff case and not much on the bevel gears. I made a wiper out of body shell polycarbonate that keeps the GS from drifting away from the gears. It collects on the wiper and is recycled back onto the gears by its own goopiness. This works in forward and reverse.
- I bought a set of Revo CVD boots and they fit pretty well around the U-joints at the wheels. You can sort-of see them in the first picture...
- That "thing" in the radio box in white heatshrink is a per-wire ferrite ring that I made out of some small pre-wound ferrite cores from Radio Shack. I forgot to take pictures while making it...
I still need to make a wheelie bar and I'll need to buy a new battery, too. The NeuEnergy pack has lost too much capacity due to storage... It cycles at 2800mAh. I need to stick with 5s as my gearing choices are severly limited........
More updates will follow.
