Ola
Ola's Avatar
04.21.2011, 03:04 PM
Originally Posted by thzero View Post
Here's, for comparison purposes, Mike's conversion chassis. I can definetly see what you are talking about with angle of the rear axle. In comparison Mike's uses standard RC8T axles, no custom ones unlike it appears the Tekno conversion.
Btw, I would definetly suggest, as you are, the plastic chassis braces. I went through several of the aluminum rod braces, bent them up pretty good, and one set of the more expensive aluminum braces. I've switched to using the plastic braces as they give some more support but also flex a bit and are cheaper to replace.
Yup, but when i go 46t and lower the center diff, then the RCM kit angles are actually way worse than mine..
And the RCM kit wasnt available anyway, so it wasnt even an option when i ordered..
The braces are Tekno`s, made only for V4 kit`s :) But i`ve read other places, that youre absolutely correct on the plastic braces vs alu..!
RC8T FT CE, CC1520, Tekno v4
