crazyjr
crazyjr's Avatar
11.29.2011, 10:05 PM
Originally Posted by PBO View Post
You want a 6mm laminated sheet? That's going to be incredibly stiff
I work with CF & a basic few tips;
-you want an epoxy glue with 60min curing time
-the faster curing time, the more brittle the resin will be
-you should allow the sheets to cure in 20-25 (celcius) ambient temp
-give the faces to be glued a good scratch with say 120p paper
-mix the resin & let it sit for a few minutes before you pour it out
-spread it out evenly with a plastic spatula
-put a little weight on the sheets once glued to ensure the top sheet has even pressure which will encourage the resin into the scratched surface
You need very little resin to make a very strong lamination & too much between the sheets will allow delamination to occur in a crash (for example)
In contrast to the advice panda was given, I wouldn't accelerate the cure with heat...heat is normally used in pre-preg not resin gluing, heat with resin can cause exotherms & you don't want that
I'm not gluing two sheets together, 3mm is plenty of thickness for the 1/10 truck. My plan is to build up the rear and the battery box, to support the shock tower. The stock chassis has a raised place to mount the shock tower, I am trying to mimic the setup. I always wanted an old school cf plate chassis and decided to do this for the T4. My plan also includes using a GT2 front suspension to avoid having to try to bend the front.
thanks for the advice from both of you, it will be used and followed
