shan75
02.18.2012, 04:27 AM
Yeah - well - no indoor tracks near me unfortunately. Outdoors bashing only so strength is really important to me. Bigger is better outdoors...
Soooo...
Decided to make life hard for myself and go with the saddled lipo config. I figure I can always reverse it back to 1 x lipo it if I am not happy. If I do it the easy way with single battery from the start and I get the truggy operational - I will never be motivated to mod it again. So yeah - will do necessary tricky chassis mods now for diff flip I reckon.
I started stripping the car down, flipped the diff and visually it appears like the front chassis brace is definitely going to get in the way of the Castle 2200kv I have on order!?!
I know other guys with this config have used the 2200kv castle combo, but yeah - while I cannot confirm for sure as engine is not here yet - I am pretty certain it will get in the way.
Scanned through the forums and there is some mention of the space limitations at front, but no real mention about having to mod chassis braces with a 2200kv motor?
QUESTION - can someone who has flipped the centre confirm for me what else needs doing in the front? Arct1k if you read this would appreciate your input as I know you have done this! Already thinking maybe I should have followed your original advice mate...
2200kv castle is approx 75mm long and 41mm wide - from my rough measurements - engine will hit that front brace. Am I going nuts?
Comments I read about flipping the diff on the hyper mentioned grinding chassis for centre diff gear clearance, but have read no mention of anything else?
Looked at all the pic's I can - hard to tell what other peeps may have done.
Grind the brace for clearance?
Shim the engine so it is angled way from the brace?
Alter the diff mount slighty? Not real keen and changing drive train alignment tho...
How the heck to you guys do it?
Appreciate any input on this.
Cheers.
