Thread Tools Rating: Thread Rating: 12 votes, 5.00 average. Display Modes
11.20.2012, 06:06 PM
Originally Posted by knuckle View Post
I wish I knew what I was doing.
Any help appreciated.
It's your lucky day:
The esc outputs 6v to the rx and servo normally, so you would indeed need to use an external BEC to power the servo directly to give it more than that; unless you have a HV rx then you can't just feed more than 6v to it ( and the servo ) otherwise the rx will go pop.
Nice simple wiring though, just grab a cheap rx connector or pig tail to get the extra connector you need ( you can just plug the signal wire and pin directly into the rx, bit it's rather fiddly ).
For a BEC, I would suggest the Castle 6s 10amp BEC- there are others around though it's hard to find one that will output more than 3-5amps and 6v.
