GT4X
GT4X's Avatar
06.24.2006, 11:02 PM
Originally Posted by squeeforever
How many cells?
As is i'm running 14cells.
Originally Posted by BrianG
Welcome to the forums!
About how heavy is your truck? Have you done anything to bulletproof your tranny (you'll need to if you want to run brushless). You'll also want to change the stock slipper to something a bit more robust like the strobe slipper.
I'd say a BK 9920, BK 12020, or Quark 125B for the ESC. The brushless motor you select will depend on type of batteries, how many batteries you want to use, and how much you want to spend. Lehners are superior motors but a little pricey. The Wanderer XLs are quite a bit cheaper but still run very well.
Thanks for the welcome! She is about 12lbs. and I was looking at the Hardened steel idler gears, the CVDs are changed since I was twisting the stocks.
