squeeforever
squeeforever's Avatar
07.07.2006, 11:32 AM
Jhautz pretty much said it all as for motor/controller but how many cells? That would determine what wind motor to get. Also, I would recommend the Feigao C motor. Its got the built in heatsink and screwed on endbells. The Wanderers are indentical inside but don't have a heatsink and have press on end bells.
As for upgrades, I would go for the Strobe slipper. Its alot better and actually allows you to set some slip. The RRP is just like stock...you gotta crank it down all the way. As for cvd's, I would go for the UE 6mm steel, but MIP would do for something slightly cheaper. The UE are by far the best though. That stuff with aluminum cases and cups would be good. If would go for the FLM Hybrid bulks with 1/8th scale gears though. Its slightly more but well worth it and you don't have to worry about stripped diffs.
