08.09.2006, 11:14 PM
Yes, Quark has its own switch. In the manual it tells you to pull out the red wire from the throttle plug if using more than 12 cells IIRC, or if you just want to use your own Rx pack/UBEC. Note: the switch shuts off the ESC but there is still some small current flow from the main batteries so you should disconnect them.
