GorillaMaxx360
GorillaMaxx360's Avatar
01.05.2007, 01:49 PM
Originally Posted by jollyjumper
i dont understand you.
i mean, why need stock size bearings if you go to slipperential, 1/8th diff and tsais cvds with 3.3 knuckels?
The HB diffs are for the diff case not the slipperential as for the cvd also are for the wheels not the slipperiential.
you wont need any of em cuz there all smaller then what you need?!?
I am not sure what you are saying exactly but i changed the list a bit i would not need the tsais cvds i would just plain need cvds because with hb diffs sliders or stock cvds will not fit on the hb diffs because they come with built in drive cups meaning i need cvds. As for the tasis ones i changed m mine i would just go with the 6mm ue ones because they are stronger. As for the knuckles i dont need revo ones i can use standard maxx size but i figured for the same price as the standard size knukles i can get the revo ones for many reason of adjustability. First if i decide to go with a different diff than hb i could possably use sliders and these knuckles would allow me to use them. Also these knuckes are cool and they are the same price so i figured why not get them but this is a minor controversy in the list. as for the bearing kit it is a full bearing kit. So i can use some bearings for the pinion gears and diffs inside the diff cases, i can also use them for the knuckles because they are sealed they give me longer life and they work better. These are minor mods on the list that i probably dont need but if i was spending the money alredy it is not going to hurt me to get this stuff. Plus even if this stuff was not on the list the same decision would probably be made because it is still a lot of money.
