starscream
RC-Monster TQ
starscream's Avatar
01.13.2007, 07:06 AM
The motor mounts are from FD but the clutch bell is home grown. You know me, I usually do things different.
I bought an aluminum gear from sdp-si.com and mounted it to the fly wheel. I mounted a revo primary shaft from the fly wheel through the clutch bell using a plastic gear as a shim for the revo shaft inside the front of the flywheel. I also used a 3mm revo hing pin to attach the fly wheel to the revo shaft (I had to drill out the revo shaft to 3mm) You can see in the pics that the clutch bell is supported by a mounted bearing in the front of the buggy. I bent one of my motor shafts in the process of testing so I added the mounted bearing in the front to alieviate the weight. It works quite well now :017:
I'm waiting for my bent shaft to come back from Tom but luckily I have a spare motor
Ha Ha
