smhertzog
Breaker of all that is Stock
smhertzog's Avatar
01.18.2007, 06:04 PM
:018: :018:
Originally Posted by Joe Ford
Fans aren't needed...we designed the controller to run without them...if you thermal the controller you're either geared improperly or there's something wrong with the controller.
I'm running a 7xl on 4s lipo in my 9.25lb Gorillamaxx and all the body holes in the world won't keep it cool after a 15min race. My alternatives are gear it down I need all the speed I got slower is not an option, cooler motor (9xl) $100 which will really slow it down, higher efficiency motor $300 OK till it gets 90 outside, lighten my truck I wont even go there, increase volts via 6slipo - then I would have to get a new motor battery and controller $500 + added weight. Or put on a $5 fan you do the math. I could make my truck much slower (9xl) or stick a whole lot of cash into something that might run a little cooler until summer comes anyway. There are no options that compare to a $5 fan. I'll make you a deal you release the Monster Max and I'll stop running a Mamba Max with a fan.:018:
You have great products, I own three Mamba25\Max controllers. Keep up the good work :027: and leave my fan alone:018: :018:
Never fight an ugly man..... he has nothing to loose
