glassdoctor
TEAM FUSION
glassdoctor's Avatar
03.07.2007, 12:36 AM
Power is watts and watts is power.... pure horsepower. :)
No doubt the best way to build power is with high voltage/low current.
The key is to resist the urge to strap in more motor than the formula requires. That will only lead back to higher amps and the heat that comes with it.
Nothing's free... it's too bad we can't just take the same motor that works well on 4s... and run it on 6s or 8s and get less current. ;) But it doesn't work that way unfortunately.
More voltage equals higher amps (and heat) if everything else remains the same. So we have to change everything....
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
