AAngel
04.05.2007, 02:33 AM
Well, there are many chargers out there that are good for the money. The 989, the Ice, and a few more that don't come to mind right now. If you want better than good for the money, in my opinion, you should be looking for a charging system where in you get either a balancing charger, or a charger/balancer combo that interact with each other. I can't recall the name of the balancing charger, but it's around $300, plus the power supply (or you can just run it on your car battery). It's made by e-station. I've never used this before, so I can only make comments based on what I've read. It's supposed to be a good charger and it will take all of the worry out of charging your lipos.
The other two are ones that I have had experience with. The first is the Hyperion EOS1210i with the LBA10 balancer. The second is the Thunder Power 1010C with the Thunder Power balancer (this is what I use). Either of the setups work in a way in which the charger and balancer interact with each other, watching out for under voltage or over voltage in individual cells and then take appropriate action. My setup, if it reads an over voltage situation, will reduce the charge current to a rate that the balancer is able to bleed off so that the cell in danger of over voltage doesn't charge any more, but the others continue to charge until they catch up, then it returns to the normal charge rate. The 1010C can also be upgraded via usb link ($30 option) to the latest software. In fact, they just released a software upgrade that includes profiles for A123 cells. Since I just use the 5 cell balancer, it cost me around $40, the charger just under $200, plus the power supply.
The Hyperion setup also has the balancer and charger interacting with each other. It is a neat setup in that you can actually network two balancers together to charge and balance two packs at the same time, which comes in handy if you are running two packs in series or parallel. On the down side, the Hyperion, as far as I know, isn't upgradeable. I've never done the networking thing though. I only run single packs. This will run you just under $200 for the charger and balancer, plus the power supply.
I really like my 1010C. I don't know what they did with the algorithm, but it charges fast. Faster than my Ice did anyway.
