AAngel
04.17.2007, 12:23 AM
I think that the 3.5mm plugs would be too small. I don't think that they are rated for much current at all.
The wires on the Feigaos that I've seen have the last half inch or so bare and tinned so that you can solder to them. The rest of the motor wires appear to have some sort of varnish on them, which (from what I understand) resist soldering.
As for my little accident, I turned my buggy chassis into a canoe. Other than that, I had to rotate the motor to use the other mounting holes, I had to get a make a new set of standoffs for my servo tray, and bend the servo tray straight. I put the chassis into the oven on 500* for about an hour and then put it into a vice and straightened it. It's running now.
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
04.17.2007, 12:58 AM
Oh really, I probably wouldn't be able to strip the enamel off the wire either... and any longer than a couple cm is pointless to do this. So, maybe just scrap that idea... :007:
Was your chassis alum.? How would 500F make it more pliable?
nativepaul
nativepaul's Avatar
04.17.2007, 10:54 AM
You can strip the enamel off motor wires, I have done it when rewinding 540s and speed 700s but its not easy, you cant just use wire stripersyou have to scrape the enamel off with a knife blade till you get to copper.
zeropointbug
Z-Pinch racer
04.17.2007, 05:00 PM
Yes, I have done alot of wire stripping (enamel) in my days. Mostly for tesla coil projects.
There would be no way to properly strip all the insulation off like you guys said. The liquid solution sounds scary as it probably WOULD wick into the motor windings! :019:
BTW, does anyone HAVE a fried 540C version motor that they could see how far the wire is actually stripped and soldered? If it is soldered just after the shrink tubing that covers all three wires, that is actually where I would like to solder it to the esc. Again, I just don't know if when the motor gets to 180F (does the 540C version get this hot?), if too much heat will leach into the esc, and IF a good heatsink will be able to handle it?
zeropointbug
Z-Pinch racer
04.17.2007, 07:36 PM
I just realized, once you solder it to the motor the way I was saying, you won't be able to get it off (at least not being a PITASOB)
