ClodMaxx
hold my beer... watch this...
ClodMaxx's Avatar
04.18.2007, 09:41 PM
duratrax recommends that it not be done on one power supply. i just found it could.
it depends on what you're charging, and what the rate is. i know nothing of lipo, but for ni-mh it won't ever pull more than what your charge rate is. or shouldn't, at least. i charge my matched IB4200's at 5 amps, so for 2 chargers that's only 10 amps out of a possible 18.
i'm doing research on charging m1 cells, and that may be a different story. some of the 'fast chargers' pull a very high current. but the Ice will still only charge lipo/li-ion at 1C, so i'm safe.
Eflite Blade 400 heli on 3s
BP-Revo
BMW M Power!
BP-Revo's Avatar
04.19.2007, 01:10 AM
Well, actually, it sends up being less than 10 amps. If you are charging a 7 Cell IB at 5 amps (one per charger). Each charger is putting out 42 watts. (Amps X Volts = watts). You have two, so thats 84 watts. Divide that by the ~85% efficiency rating and you get 98.8 watts input. Take that, and divide it by the 13.8v output (what most powersupplies put out), and you find that its pulling about 7.16 amps.
However, when charging NiMH cells, voltages rise well above the 1.2V per cell, so thus the amp rate will increase. However, I was just pointing out that its all based off watts. When I charge 4S lipo at 8 amps, it pulls something like 10amps, because it must do 8 amps and bump up the voltage to 16.8.
