Patrick
Patrick's Avatar
04.26.2007, 05:09 AM
I didn't know what voltage you were going to use, so assumed 4s or 12 cells. That's why I suggested a 7t, but for 16 cells I would say the 9t. An 8t would work, but you might have a problem with heat (I'd be more worried about heat in the Quark [if you get the Quark] than the Lenher) and run time depending how you drive it.
The 10t would work too, but top end won't be that great unless you gear it up a fair bit.
The 9t would probably be a good balance, but it just depends how your going to use your car and what you want it to do to decide which motor to get.
