04.26.2007, 04:46 PM
Yes, Integy stuff..... sucks. It looks nice, but I would only use it in places that arent likely to suffer in a crash/flip/roll. What are you going to replace them with? Looking at that graph Im amazed- I expect a graph of my batts would look like a rainbow..... impressive truck that you got there.
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
04.26.2007, 06:23 PM
yeah, thanks, I'm pretty happy with it. I'll prabably get some FLM bulks, or I might just take her easy and wait a bit and get some hybrid bulks w/buggy gears.:027:
If you are wondering about the batt graph, that was just a bench test with a constant discharge from two large 820 motors. The voltage is way off, by like 1.5 volts. I still can't figure it out.
I'll go do a run as soon as I can with the Eagletree in it, until battery dumps.
zeropointbug
Z-Pinch racer
04.26.2007, 07:13 PM
K, I did a run, but it was cut short. I don't have a good servo saver yet, and I did a high speed cartwheel and broke the servo arm off.
Anyways, it's the last two pics/screenshots of Eagletree titled Short B-Maxx run... This was ran on hard packed gravel, with loose layer of sand/stones/etc.
HERE
cabojoe
04.26.2007, 07:59 PM
I had to sign up to tell you that is one well done Maxx. That is the direction I've been headed, and you just sealed the deal on the FLM chassis for me. Clean job, not too much heavy bling. I'm brushless ready with all the driveline upgrades, and hope to have my truck looking as clean as that. Well done.
zeropointbug
Z-Pinch racer
04.26.2007, 10:18 PM
Thanks man! I'm honored that you registered just for me! :027: Welcome to the forums!
I'm pretty happy with it, over time I will upgrade to cream of the crop parts for strength. My next upgrade, AND soon, is a new radio. I only have about 100 feet range, and even then it glitches alot.
It's not as clean as i would like, as this is the only setup I can do, because of the batteries are too bulky, they barely fit in width wise, and length wise.
Thanks ***RC*** !
zeropointbug
Z-Pinch racer
04.26.2007, 10:29 PM
Is that normal power consumption I have with the 7XL? I have 135 amp spikes whenever I blip the throttle, and the power consumption hits 1935 watts.
Also, I mounted the Quark to the FLM chassis, and it seems to suck all the heat away from it, it runs very cool after a full hard run. :027: THe area near the Quark (alum.) is slightly warmer than the rest of the chassis. It's a good heatsink.
luvsrc
RC-MONSTER BRUSHLESS FANATIC
luvsrc's Avatar
04.26.2007, 10:34 PM
Great job on yout truck man and It looks good too. :027:
Brushless Jammin Truggy on NEU 1515 2.5 D on Monster mamba max with maxamps 5000mah 6s Lipo
Gorillamaxx Revo CF version on Mamba maxx ESC with NEU 1515 1Y on Maxamps 4s 8000mah Lipo
