squeeforever
squeeforever's Avatar
05.07.2007, 08:20 AM
I had one fail as well. It was quite odd though. I think the motherboard and/or processor failed, causing the hard drive to fail. The hard drive was so hot it started to melt the plastic on the bottom of it.
hyperasus
hyperasus's Avatar
05.07.2007, 08:25 AM
That sounds like a power supply failure to me. Those buggers can take the whole pc with them. Power supply is the most under estimated component in your computer.
squeeforever
05.07.2007, 07:57 PM
Thats what I thought as well, but it seemed to check out ok...
Brian, you might want to consider the AMD Athon64 X2 4200+. Its a AM2 socket, so it will require a new motherboard. I would recommend the
nFORCE4M-A HT2000. That, in combination with a nVidia GeForce 6600 OC. I have that in the computer I'm using right now, and its probably the fasted computer I've ever used. Of course, I have it slightly over clocked, but it still runs under 30* C. I could probably go up alot more, but don't want to push it.
