All this sucking and blowing....hmmmm, well, no comment.
:026: :005:
The design is actually pretty good... IMO, I would just run it fanless, it looks like there is plenty of surface area int hose fins. Aluminum though.
A4, also, I was looking at the other pics. Why do you have the slot where the Quark mounts? Was this supposed to be THE Quark case instead of the alum. Quark case?
If that is the case (no pun intended), then that would work fabulous for dissipating heat as there is only the FET's and the then the heatsink, and you definitely would not need fans.
So you would take the board out of the Quark case and transplant it then?
I want to make a controller case for mine, still thinking exactly how to do it. You see, I want mine to have the top set of FET's coupled to the case as well, I really don't like how they are not.
