GriffinRU
05.13.2007, 06:14 PM
I do not know what is going on, but:
Batteries internal resistance does change with charge! Otherwise you should be able to drain the battery for long time with now change in voltage drop under load...
Battery will be charged only if voltage generated by motor upon braking is higher the battery voltage (which is usually NOT) so for ESC to charge battery it suppose to have additional circuitry which boosts this voltage to higher levels (assuming we have only two wire going to battery!)
All hands for theory and understanding here!
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
05.13.2007, 06:29 PM
here here
Gustav
Gustav's Avatar
05.13.2007, 07:18 PM
do controllers have this additional circuitry?
If the voltage generated is lower than the battery voltage and we didn't have this circuit to boost the voltage then where would the energy generated go?
