Dagger Thrasher
I have no idea what's going on
Dagger Thrasher's Avatar
05.14.2007, 05:20 PM
Well, I think I've decided on a setup; a 7 or 8XL Wanderer, with a 4S MaxAmps 6000mAh lipo battery and an MM. As for mounting the battery...well I've stripped most of the truck down and this chassis plate has got to be THE most difficult plate to mount a brushless system on! No matter what I thought of (mounting the batt on the rear, front, reversing the centre gearbox, having the motor in the front, etc) nothing would quite fit!:035: I do have an idea though...and that's to simply make a battery plate (perhaps 3mm ali) that extends off the side of the chassis. It should be strong enough, and will look ok once I've stripped the anodizing off the chassis. I'll relocate the brake servo to the front, and have the motor mounted on the other side of the chassis to maintain balance.
Anyway I'll shutup now, as I'm sure this isn't very interesting to ya...but I'll post updates when I get started in a few months. Gotta amass some funds.:027:
