GorillaMaxx360
GorillaMaxx360's Avatar
05.18.2007, 04:34 PM
Ah i had the same problem. I bought hb diffs and tsais cvds. they would not fit in the cups so i grinded them down. They became considerably weak and i broke the pin with my hand on one. i emailed mike and he told me (after i grownd down one cvd) i could use savage diff cups and they work fine with hb diffs because it is a co company to hpi and there diff construstion is simmilar. This will fix the problem of two small diff cups. Though because i had one growned down shaft and 3 goods, ther was no use in using them so i traded 3 t-bones for 4 sliders, and i am currently using the axel stub mod which works like a charm. I am getting 3.3 mip cvds in about 3 days though
OldSoldier
E-ReVVo/SoldierMaxx
OldSoldier's Avatar
05.19.2007, 08:44 PM
Can you lay out what steps I would need to take to covert to sliders? I can't visualize how sliders connect to the drive cups of a Hotbodies diff. Do I need to go back to stock diffs to use sliders? I need to solve this before Memorial day weekend.
hi there!
overkill5000
gmaxx addict
overkill5000's Avatar
hi there! - 05.20.2007, 10:34 AM
i had the same problem and had to buy some UE cv's the longest ones they had and had to use a small spacer that came w/ the cv's .....if you use the spacer you will not have as many threds to screw your wheels on to, but it still works great w/a little lock tight!!!:025: i didn't know how to use the sliders and besides that the torque twisted my sliders!!!!!
Hot Bodies diff cups too small for tbonz CVDs
OldSoldier
E-ReVVo/SoldierMaxx
OldSoldier's Avatar
Hot Bodies diff cups too small for tbonz CVDs - 05.21.2007, 08:27 AM
Does anyone know if MIP CVDs will fit into the drive cups that come with the Hot Bodies diffs?
OldSoldier
wallot
wallot's Avatar
05.21.2007, 09:07 AM
OldSoldier
MIP and UE will fit
some cheaper alternatives with dust boots like THS do not
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
