Aragon
05.19.2007, 09:30 PM
I agree with zpb. I'd also like to raise another question on this talk of ABS...
ABS is an abbreviation for Antilock Braking System. By saying antilock one assumes that there is a mechanism in place to detect when locking occurs so that action can be taken to avoid it.
Do ESCs even do this detection?
I have a suspicion they do not, and I also think that they don't really need to.
As ZPB already pointed out, a motor's braking force increases with RPM assuming a constant shorting resistance across its poles. This leads me to think that ABS would be unnecessary in a brushless braking system as the motor itself naturally applies less braking force as it slows down.
The only time I can see ABS being of value is if there were devices monitoring the rotation of the wheels themself so that braking force could be released if only one wheel locked (while the diff action kept the motor spinning).
What do you all think?
GriffinRU
05.19.2007, 09:38 PM
The key element of ABS is to keep track on traction (maintain traction), have nothing to do with RPM
Aragon
05.19.2007, 10:10 PM
Yes, but avoiding a wheel lock (or skid) is a key part of maintaining traction. Static frictional force is always greater than kinetic frictional force given the same two surfaces...
GriffinRU
05.19.2007, 10:38 PM
You lost me here, or smth else
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
05.19.2007, 09:51 PM
Yeah, it's not true ABS (like the Quark), it's just the controllers algorithm controlling it. It knows how fast the rotor is spinning, etc.... there is a minimum rpm the motor can spin when shorted anyways.
It is quite simple how it would 'detect' the rotor rpm, it's just a matter of making a good algorithm to do some braking magic. I imagine that controllers only use a fraction of the motor braking resistance.
GriffinRU
05.19.2007, 09:59 PM
Of course controllers do simple things, we do not have individual sensors and brakes per wheel, but idea is the same.
And check your last statement, because it is the motor which stops the vehicle not the ESC or Battery
zeropointbug
Z-Pinch racer
05.19.2007, 10:28 PM
I know that, I was stating that it's up to the controller to do good braking, as many ppl here know that different controllers have much different braking characteristics.
zeropointbug
Z-Pinch racer
05.19.2007, 10:36 PM
The software engineers of the controllers are putting 'assumptions' into the algorithms, if you catch what I mean? It's hard to explain this. But also, maybe it's monitoring current levels, and there is a max?
A simple braking alg. would prob do some pretty decent braking effect. But who knows how sophisticated they are, or maybe they are simpler than one might think?
GriffinRU
05.19.2007, 10:41 PM
I don't think so, but it is Ok to assume that :)
zeropointbug
Z-Pinch racer
05.20.2007, 01:05 AM
what do you mean?
