05.31.2007, 05:15 PM
Hey Serum, you reckon the 6.5 motor (3100kv) would be a good improvement over the original 4400kv motor? Im thinking on good quality 7 cells packs (16.8v), it would have more speed and torque, and run cooler thanks to the new sintered rotor..... What do you reckon, from a hyperthectical view point?
A new 6.5 motor only cost £60 /$120 ish from tower (£100 in the UK, geh?), so it might be worth trying- cant be any worse/slower/weaker/hotter.....
ClodMaxx
hold my beer... watch this...
ClodMaxx's Avatar
05.31.2007, 05:20 PM
a new rotor is only $35, and would be cheaper than the motor kit. when the 6.5 came out last summer, i had just purchased my 4400 system and called novak to see if they recommended the 6.5 motor, or just install the new rotor. they said the only things new were the rotor and the ribbed endbells to control heat, but that the endbells didn't really dissapate all that much. they recommended just installing the new rotor. it's pretty easy to install too, just make sure you grip it with pliers - hard - and slowly insert it. the magnetic pull is super strong, and could damage the sensor at the back of the can if it slips.
the sintered rotor does cut heat a lot, and the braking power is immense compared to the 4400. i didn't really notice much of speed boost though.
Eflite Blade 400 heli on 3s
05.31.2007, 05:41 PM
Yeah, the rotor on its own would be alot cheaper to buy, but Im thinking about the KV ratings.
The old HV4400 is 4400kv, the 6.5 motor is 3100kv, and the 4.5 motor is 4800kv. With more turns and a lower kv the 6.5 should have better torque and run cooler than the original motor, even on 14cells ( I have seen a few videos of the 6.5 in revos and I like what I see):024: :cool:
