06.01.2007, 09:50 AM
Originally Posted by no mods
ah ok .. i was worried that it may terminate a bearing by being unbalanced but it seems like its a non issue. thanks
If you are worried about balance issues, just remember that the set screw helps offset the imbalance caused by grinding the shaft. In fact, you probably have more imbalance if you DONT grind the flat spot because of the set screw...
