What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
06.05.2007, 12:48 PM
If your using end-to-end joints, you need to make sure BOTH sides of the joint get soldered. I had some problems with the solder not flowing around the whole wire, even with both sides tinned. In that case only half of the joint's cross-section would be soldered at most. Most likely this would cause localized heating and the joint would fail. The one thing that gets me is that they ALL failed, at the exact same time, too, because otherwise not all of them would have failed.
Edit: LOL. This took a while to write but BrianG has the same idea.
jhautz
jhautz's Avatar
06.05.2007, 01:17 PM
I didnt think I had any issue with the solder joint. I had the sloder flowing very well on the surface of the trace. It was one continuous bead. I wish I would have taken a picture of it after it quit on me. It looked like it flowed perfectly to break the connection on the trace. It was claner than the ones I broke on purpose. I just resoldered it and this time used alot more solder. Its just a taller bead that I used this time. It must be that there just wasnt enough cross section to handle the current and it heated locally. Its the only thing I can think of.
Edit: It wasnt a cold solder joint. If you saw it in person you would understand. I dont think it wouldbe possible to get it to bridge the gap and be a cold solder joint. Its not like a little bead sitting on there. The entire trace on the back of the motor is completely covered in a heavy bead of sloder. I can tak a picture of it later tonight if you want to see what it looks like now.
Brian. I was able to heat the solder to the point here it flowed on the trace when I tipped the motor side to side. Getting it hot ebought wasnt really a problem. I used a 50W Hakko soldering station jacked up all the way to 900 degrees.
to make it...
or break it...
Silent...But Deadly
