Procharged5.0
Procharged5.0's Avatar
06.05.2007, 05:10 PM
Welcome to the forums! You are in the right place fo tech info!
All three will bolt in.
If you are using electric motors (brushed or brushless) install the emaxx trans with RC-Monster steel idler gear(s). That is "THE SET-UP" to use for bashing and/or racing. If you are racing only (assuming you are running brushless) you can also use a gorillamaxx single speed conversion which is based or the E-maxx trans as well.
