pullstarter
Pullstarter
06.12.2007, 07:04 PM
I used the ofna alum servo horns which have a plastic spline insert, like sven says it's a good weak link to use as they will most often strip out before the servo does.
dabid
09.22.2007, 04:30 PM
I know it's almost 3 months later, but in case anyone is still wondering......
Most guys do not run servo savers because the springs are too soft, when the front gets bound up but you still want to turn the wheels to drive out of it, the spring will take away all throw from the servo and leave you with the wheels pointed straight. Usually, guys will go with the heavy duty DuBro servo horns instead, which stay tough except for the absolutely hardest of hits.....which will kill the horn instead of the servo, in theory at least.
Oh, and the best bang/buck servo out there still has to be the TowerPro 995MG with 200oz/in of torque and .15 sec transit for around $10. They're getting harder to find though, because supposedly they were taken to task by Tower Hobbies, so they're now being sold under the HexTronik name.....I think its the 12kg one, but I might be wrong. Basically, these servos are the generic version of a high end high torque/high speed KO Propo, just not stamped with the more expensive name in Hong Kong or wherever they're made.
