06.12.2007, 08:43 PM
Yeah, I was responding to you, sorry for the confusion. :)
If you are using stock tires should be fine with a 5700 on 2s, geared with a 13T pinion.
skellyo
skellyo's Avatar
06.12.2007, 08:57 PM
I'm not going to use a 5700, but the GM-Racing I'll be using is 6100kv. I ordered a 12T and 13T, so I should be able to hit a good middle ground with one of those. I'm running the same motor in a T4 at 38mph with temps under 140F for both the motor and ESC after 30 minutes of running in low grass in 90F weather. With the 12T pinion, I should realistically be around 35-36mph, but will have to keep a check on my temps to see how the motor handles it. I'll definitely throw my GPS on it when I get it running (hopefully this weekend since my pinions should be in by then).
cemetery gates
06.13.2007, 05:37 PM
Alright guys, I talked to a friend that is really into brushless to see if he had any motors he wanted to sell. He has a FDM 10L and a Lehner basic XL 3100. He actually gave them to me to try out. If I want them he said $50 for each, $100 for the pair. One has 5min runtime on it, the other one has 6min runtime on it, so they are practically brand new! Should I just get them both? I have no way of testing them now though. What do you all think?
Thanks
Bye:018:
