Mightytaco
06.18.2007, 06:58 PM
I bought two of mikes mounts, one for a ofna 9.5 and one for a hyper 8. I cant say for the R2, but the jammin plate was a direct fit on the 9.5, and workable on the hyper 8 with some small mods. The hole spacing is a tad wider on the chassis holes if i remember right, and you will need to shim the front half of the diff mount up a bit for the diff to line up level. Hole spacing on the mount on the bottom/chassis side is 22mm. Hope that helps, it's a nice mount!
