rchippie
rchippie's Avatar
06.19.2007, 11:10 AM
Are lipo's like nimh in respect to when the charger shows they are finished charging you have to use them right away to get the best performace, or can i use them two or 3 days latter ?.
REAL MEN RUN BRUSHLESS
MetalMan
MetalMan's Avatar
06.19.2007, 12:50 PM
You can use them three days later and they will still be almost fully charged, and there won't be a power difference after three days. However, it's best to keep Lipos at about 3.8v/cell when not in use (storage), so keep that in mind.
rchippie
rchippie's Avatar
06.19.2007, 01:03 PM
Im new to this lipo stuff how can tell if each cell is 3.8 & will it hurt if i store them higher than 3.8 ?. I'm assuming i can just measure the pack voltage as a hole ?.
I just figured out i can use the balanceing tab to measure each indaviduel cell.
06.19.2007, 01:12 PM
I usually just run my vehicle for about 1/3 of the normal runtime. That typically sets the voltage right around 3.7-3.9v per cell. Yes, you can measure the pack as a whole and divide by the number of cells, but this assumes the pack is balanced.
rchippie
rchippie's Avatar
06.19.2007, 01:14 PM
Does it hurt if you store them with more than 3.8 per cell ?.
06.19.2007, 01:17 PM
I can't remember exactly what happens when you store over 3.8v, but I do know it is better for the cell. I don't think it will explode or anything.
rchippie
rchippie's Avatar
06.19.2007, 01:21 PM
So after your last run of the day what is your rutine for storing them ?.
jnev
jnev's Avatar
06.19.2007, 01:45 PM
Is it bad if they are stored for a couple days with no charge? I ask because I am waiting for my charger in the mail, and surprisingly, the battery came fully charged, so I ran it.
jnev
jnev's Avatar
06.19.2007, 10:21 PM
Anyone know? Sorry for the thread hijack...
06.19.2007, 10:43 PM
A couple of days is ok. A week, maybe. Longer; run it down to 3.8v/cell.
jhautz
jhautz's Avatar
06.19.2007, 10:52 PM
I wouldnt leave it for longer than you need to. I forgot to throw a little charge in one of mine once and it was fine a few weeks later. But it wasnt 3.0v/cell to start with either. Its best to store them with a little voltage in them. but you will probably be ok as long as you didnt run it down to far.
to make it...
or break it...
Silent...But Deadly
jnev
jnev's Avatar
06.19.2007, 11:28 PM
I ran it down until about 12.5 volts. I hope the charger come within the next two days or so, so I don't have to start freaking out about the battery.
rchippie
rchippie's Avatar
06.22.2007, 04:33 PM
what should the volatage be on a 4s 8000 pack be when fully charged ?. Thank's
jhautz
jhautz's Avatar
06.22.2007, 04:41 PM
4.2v per cell.
16.8v total.
to make it...
or break it...
Silent...But Deadly
rchippie
rchippie's Avatar
06.22.2007, 04:46 PM
Originally Posted by jhautz
4.2v per cell.
16.8v total.
Thank's thats what i thought. My charger shut off before it got to 16.8. I just called maxamps & they said sometimes that can happen. He said it was safe to put it back on the charger . I guess it might have false peeked or something. I did balance them before starting.
