crazyjr
crazyjr's Avatar
06.20.2007, 03:23 AM
the problem i see is that you got a 2.32 ratio on Pinion/spur and 2.72 in tranny, which comes to 6.32:1 total ratio. For stadium trucks you need a 12 to 14:1 ratio total to run proper, so it was my latter suggestion was what happened. Usually that ratio (the one you got now) is usually run in touring cars
ill_tempered_02
06.21.2007, 07:59 PM
do you think that a 17 tooth pinion would be better? or wiring the motor to the hv setup?
I run a fagieo 6l on 6 cells and I use 17/51 and it is cool as can be. I could even put a larger pinion on.
