06.22.2007, 01:18 PM
Welcome to the forums csummer!
There are a few e-jato conversions around. I've done two myself (the "BL Conversions" link in my sig). The only problem I have is getting the power to the ground. It helps to add a little weight in the rear battery box if that is a problem.
csummer
06.22.2007, 02:10 PM
I used the rcmonster revo mount but I didn't modify the chassis. I modified the rcmonster mount. I cut the side off where it gets small and then redrilled the holes in the mount as far to the opposite side of where they were origiinally. Then I just mounted it on top of the original motor mount that came in the jato so I can adjust gear mesh with the screws in the bottom or the ones that go into the motor. I may end up having to buy a better motor mount that is not cast like the traxxas one is and I also might have to take a little material away from the front of the transmission housing depending on what pinion and spur I end up using for clearance.
