padailey
06.27.2007, 12:10 PM
Well what you have listed will work fine but you may want to consider a couple things. First the Hyperion only charges up to 5 amps... so your batterys should be limited to 5000mah or less and I don't know about the price because it isn't in US dollars.
Secondly you are getting a power supply so do you need an AC/DC... there is a Hyperion EOS 5 which is only DC and cheaper but should provide the same features.
Going by the prices I've seen at US sites a better choice for the money would be an ICE which is more versatile, charges larger batteries, motor breakin, etc. Or if just for Lipos might I suggest the Astroflight 109 which is excellent for lipos and in the same price range. Both of these I would say are better charger choices for around the same price tag as what you have listed. Of course it all depends on what "you" can find in your area.
