08.24.2007, 09:04 PM
The 9L will be strong enough if you keep the 2 speed tranny. The only downside to the 2 speed is that you can't use the motor for braking or reverse.
Other than that, the drivetrain is pretty tough. I've only broken the pins holding the gears to the shafts inside the tranny, but upgrading to the slightly larger Jato outdrive pins fixed that (and a little shaft/gear modding to get them to fit).
I would stick with 4s if using the Mamba Max ESC. It should be able to handle 5s, but IIRC, some people say it acts funny. Besides, 4s is plenty for a 9L.
david lamontagn
08.26.2007, 04:33 PM
Brian could you tell me what's your custom 4 spyder diff?? And does this mod bulletproof the tranny or the stock will be fine?
And should i lock it in second gear?
thank's
08.26.2007, 08:58 PM
thank's
You mean the custom center diff? I got it from Squee a while back, and now Mike has it so he can take a look and possibly copy it and maybe make it better. The Jato pin mod does make it stronger; I haven't had any trouble since I did it. With the stock pins, I broke a couple. If you are running a 9L, you shouldn't have any problems since it's not quite as torquey.
david lamontagn
08.26.2007, 09:14 PM
OK if i understand well, the easy and cheapest way to convert my revo is to take a RcMonster motor mount, put my 9L on it, install a FOC kit on the tranny (because i don't want to have reverse), installl a better pin on the input shaft and lodk the tranny in second gear (i'll want to keep a servo for the break, don't want to break with the motor to drain less current from the batt) and buy a FlightPower 5000mAh, 14.8 volts li-po pack??? That's it??
