09.02.2007, 01:19 PM
Originally Posted by Hernz
I have one of the only ones made. They didn't go into production though because of cost.
09.02.2007, 01:36 PM
Originally Posted by squeeforever
I have one of tthe only ones made. They didn't go into production though because of cost.
ya thats what i heard price was too much to produce them.
and like jnev said i will for sure to gas to electric because of the quality its just i need to find the right one.
if i kept the t-maxx itd only be because i have a COMPLETELY upgradred one. i dont like how it drives at all. doesnt handle very well.
if i did a revo it would be cheaper cause i already have a nice roller and everything. i have ALOT of spare breaks too if i break anything.
so i dont know!!!!!!
im aiming towards a revo though since i have evertyhing, but after reading what paralyzed said the savage sounds awsome.
09.02.2007, 01:52 PM
Im just curious why do people say you need to convert the LST with an E-MAXX transmission. My lst transmission is holding pretty well.
09.02.2007, 01:56 PM
Pinion problems I do believe. Metal on metal always results in a stripped pinion.
I've seen some very valid points about why go with something other than the Revo, but keep in mind, the Savage for example requires upgrades as well. There not indestructable from the factory. Like the the 2nd speed tranny gear. If I remember, it doesn't hold up to BL all that well and needs to be upgraded to the HD part. I would still go Revo, no matter what. They handle AMAZING, no matter how horrible there setup, and they don't really need any upgrading from the factory, when avoiding nitro. For example, biddy said he had problems with pushrod ends getting sloppy. I've never really had that problem unless it was the ones under the rear pipe. Mainly the shock ends. They do need to be upgraded to aluminum, but thats only a nitro problem. Personally, I think its one of the best trucks ever made. Yea, it might not be indestructable, but its damn near it.
09.02.2007, 03:11 PM
Stock LST spurs are plastic. So its metal on plastic.
09.02.2007, 06:10 PM
Oops...I got that and something else confused. Its the 2 speed then I would assume, correct? Don't they need a 2 speed clutchbell?
RCM Brushless Savage
09.02.2007, 07:30 PM
I've had a REVO before and honestly it just wasn't beefy enough for my likings, though it did withstand the horrible beatings I put it through like purposely landing on its lid from 30ft. repeatedly I just couldn't get over how it wasn't a true monster truck IMO, that's why I'm now using all the FLM parts I can get to create the ultimate savage with a center diff(ext. low cg tvp's, ext. a-arms, combo bulks, skids, servo mounts, ect.). It still wont handle as well as a REVO but I'll have more confidence to beat the hell out of it. Any way you go, anything will take quite a bit of upgrading in certain departments, basically it's what fits you best, price, availability, and personal likings are what should matter most.
The wisest mind has something yet to learn. (George Santayana)
09.02.2007, 08:46 PM
Stock it does, but its quite easy to make one speed.
09.02.2007, 10:07 PM
one speed might be a little slow then correct?
anyways im going with the revo. i have a nice chassis already (upgraded shocks, shock holder thing, rpm arms, rpm carriers) and plus i have a SHIET load of tires and rims for it and not to mention bodies... and spare parts.
once i got the truck running i noticed a HUGEEEEE freakin amount of torque (im only using an hv-maxx 4s lipo.) it has uncontrolable torque! haha! i can flip on the back like nothing!! i want to tune this down a bit... i was thinking that the only way to do it is gearing correct? im thinking about adding a couple teeth to my spur and pinion each.. how will that affect it?
also while i was running it i snapped the pin inside the tranny...the one that is right behind the spur gear... where can i order this peice at?
and here is my first real problem... i noticed it was steering left a little so i adjusted it. it goes perfectly straight untill i floor it. once i give it some gas it leans to the right and if i try and correct it just a LITTLE it will veer to the left and flip (over correcting the skid... sort of) im not sure if my shocks are all off or something causing it to lean maybe? or maybe my tires are gripping enough? (using badlands)
if you guys have ever had this problem let me know!
thaks for all your help!
09.02.2007, 10:21 PM
Not if you lock it into high, still has enough torque to flip the car over.
09.02.2007, 10:30 PM
The Revo was a good choice.
Veering to the right would be because of unbalanced weight on each side. The pin breaking is known to happen because of the torque... BrianG told me. He said that with a small mod, you can get the Jato drive pins to fit and they will be much stronger. Watch tempos when changing the gearing. The Novak systems are a lot more sensitive to gearing changes then other systems and will heat up a lot at a time if the temps are not watched.
BTW - Let me know if you want a nice radio system as well, I have got three of them for sale (Airtronics M11 and two Airtronics MX-3s radio systems all brand new).
09.02.2007, 10:51 PM
ya i figured it was because of the torque... and i dont understand why my weight would not be distrubuted correctly... all the electronics are straight down the middle and then i have the 2 batts off to each side equally disporportioned.. doesnt make any sence!!
and im using spektrum right now so i am pretty much good to go!! thanks though!
Brushless Heavy Weight....
09.02.2007, 11:16 PM
LST2 Get's my vote as well.. by far that's my favourite all around Monster Truck.. it was good for bash and race... Tranny was tough, diffs were tough.. It's a nice truck...
09.02.2007, 11:21 PM
Isn't that called torque steer?
09.02.2007, 11:24 PM
the veering could be a diff issue. if more power is going to one side of the truck than the other, it will cause it to veer off line.
you might want to have a look at the diff gears, since a loose gear meshing will result in the teeth slipping over each other.very bad. likewise, a too tight a mesh on one diff output compared to the other side will cause unequal power distribtion (left and right).
also, check to see that the axle carrier bearings haven't packed in on you on either side of the truck.
if the bearings have siezed, then more power will want to go to the wheel with less resistance. this would also result in the exagerated veering left when you plant it.
i am assuming that your steering linkages and servo saver a working correctly.
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
