glassdoctor
TEAM FUSION
glassdoctor's Avatar
09.03.2007, 02:48 PM
Is the system still working now or is it dead? Maybe you just hit the voltage cutoff after 15 min.
Next time you run... and the motor is "hot".... try a finger/spit/water test. See how long you can hold your finger on it. or if it's really hot... if a drop of water sizzles :)
If the esc temp is a lot less than the motor, then you can try gearing higher. (bigger pinion)
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
