09.05.2007, 09:50 AM
The screwdriver is simply a metal rod. Any induced voltage would be VERY VERY small (in the nano volts), and screwdriver "coil" is oriented the wrong way for an induced voltage to spin it. Also, the A/C case is sheet metal, so that is going to block any magnetic fields from the internal motors.
I don't think I could even try to duplicate it with anything else since this was very random/arbitrary and just happened to do this.
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
09.05.2007, 04:45 PM
Yeah, I have seen stuff like this happen to me lot's too Brian... something about the vibration, just don't know how?
Biddy, you are forgetting 'Zeropoint Energy'.... the amount of energy in empty space (vacuum), which is the entire universe since an atom is made up of almost nothing as well.... anyways, the amount of energy in one cubic cm is 1x10^93 grams of mass energy (e=mc2 energy).......that's big, that's big.
Many labs around the world are reporting phenomena where getting weird readings/input/ouput, and other strange unexplainable things happening.
Is there any reason that this seemingly infinite supply of seething energy cannot be tapped and used? Indeed ask yourself this question, 'what created this universe, energy, consciousness, or both? Energy and consciousness are what this universe is made of, with the grand illusion of seeming solid and materialistic.
If you want to see a really great 'documentary', go and get yourself a copy of 'What the BLEEP, down the rabbit hole.' You will be thoroughly enlightened.
