09.05.2007, 05:37 PM
Originally Posted by cemetery gates View Post
BTW BrianG, what was the math again to see how much runtime you would get?(ex: 8Ah lipo, you draw 10amps average, you get X runtime)??????
- Since we measure runtime in minutes, multiply your Ah rating by 60 to get Amp-minutes.
- Then divide by the runtime you get (in minutes) to get average amp draw.
- Or, divide the amp-minutes by a known average amp draw to get runtime in minutes.
You can use this information to figure out how much extra runtime if you get a higher capacity pack. Example: Let's say you get 10 minutes on 3.3Ah cells. That is 19.8A average. If you upgraded to 8Ah cells, you'd get 24 minutes of runtime. Really, you could just divide 8Ah/3.3Ah to get a capacity ratio, and multiply that by the present runtime to get the same answer, but the other way seems to make more sense to people for some reason...
If you know you get X minutes on a given pack, you calculate the average amp draw. Then, a general rough rule of thumb says that your peak current draw will be about 6x your average draw. So, if you are drawing 15A average, your peak will be around 90A.
For a 8Ah pack drawing 10A, runtime will be around 48 minutes (8Ah X 60 minutes. 480 Amp-minutes / 10A is 48 minutes). Of course, since batteries hardly ever reach their rated capacity when drawn heavily, you can shave a few minutes off that.
