lutach
lutach's Avatar
09.10.2007, 03:38 PM
Originally Posted by JPP View Post
Since I've been trying to program over and over again, I actually wound up writing out clearer instructions (similar to what jhautz just did) in Word. It reduced the stress level significantly (although not as much as if I had been able to program successfully!). That said, I've never had to do that with my Castle, Novak, or Quark controllers!
Incidentally, one other thing I noticed is that to get mine to recognize full throttle, full brake, and neutral, I have to set the throttle subtrim to somewhere between 15 and 25 (where, exactly, seems to be random, depending on the time I turn it on), and the EPA on brake to 10 (out of 100). I am able to leave the throttle EPA at 100. I'm running a Nomadio React, have 4 other vehicles on the same radio and have never had a similar problem. Is this normal?
JPP
Your radio might be the one to blame. I just programmed my MGM with a JR and a Spektrum and the controller worked the same as it did with my Airtronics.
