gasshead
j-womp
gasshead's Avatar
09.16.2007, 09:22 PM
i got one, but still need to get another castle link to program it. its crazy small and should do quite nicley on my revo with only one servo and 3 fans
  Send a message via AIM to gasshead
BitHed
09.18.2007, 03:20 AM
..i have one enroute from Kansas to Japan but the shipping addres got 'muddled' and it looks like it might actually bounce back to CC and then have to be re-shipped :( Bummer...
magudaman
09.26.2007, 03:24 PM
I got mine from the LHS and it works great so far. I did some testing with the stock voltage setting at 5.1v and took it up to 6.5 amps and the voltage drooped down to 4.5v with 18.6v input. The unit from my calculations was still something like 91% efficient. My LHS has a castle link for customers so I had them boost it up to 6.4v for my emaxx, I am running 3 fans and 144oz servo.
THE ONLY THINK I DON'T LIKE: is their thin output wire, it like 24-26ga and 1 foot long. Most of that voltage loss at 6.5 amps is probably in the wire.
BitHed
09.26.2007, 11:50 PM
..yay! :D Mine has arrived and fitting it up...Have to agree with Magudaman though...prettty whimpy wires...would it be worth changing them or too much hassle?
magudaman
09.27.2007, 12:02 AM
Im kinda afraid to cutoff the Shrink wrap as I can see two PC boards inside, It also seems that the wire is soldered flat to the PC board not through.
BitHed
09.27.2007, 12:06 AM
...i was thinking that too...I might give it a shot and see what happens...I have a funky little alloy heat sink that fits perfectly too...Ok...I will redo the wires and if it all turns to poo then no problem
magudaman
09.27.2007, 12:12 AM
Hey take some photos of the inside if you can and post'em up or at least email to me, I might end up doing the same this weekend (replace wires).
