lutach
lutach's Avatar
09.18.2007, 08:31 PM
Originally Posted by crazyjr View Post
Let me get this straight, you burned 3600 mah and took 2000 in? That sounds like getting something for nothing, thats almost impossible. Good find, i might have to try some
I actually pushed them a lot more than I would have with other packs. I thought that was strange, but it might be a misreading on the DPR-II-150. The first few graphs everything seems to line up right, but now as you can see the Max 128A doesn't line up with the graph. I tried downloading the newest firmware again to see if it helped, but it didn't.
lutach
lutach's Avatar
09.20.2007, 11:56 AM
I ran the MaxAmps 11.1V 4000mAh packs yesterday and it didn't perform like the smaller 11.1V 2200mAh packs did. I had to stop at around 8 minutes due to the packs heat and a swelling issue that was uncomfortable to see. The swelling has gone down and they charged ok, but I'll just run them on my Stampede from now on LOL. I will run the KongPower 11.1V 2200mAh today and see the results they give me.
Name:	Ofna MBX BL, BK 3695, Hacker C50 13L, 11.1V 4000mAh MaxAmps in series-A.jpg
jhautz
jhautz's Avatar
09.20.2007, 03:43 PM
were you running th 2200 packs in parallel? Thats the only way I could see these things putting out that kind of amp and run time. On a 2200mah pack 128Amps would be 58C and the total discharge of 3600+ mah makes no sense.
These must be paralle numbers. which bring the peak discharges down to a more reasonable 29C
to make it...
or break it...
Silent...But Deadly
lutach
lutach's Avatar
09.20.2007, 05:04 PM
I was running them in series. The voltage was at a little over 25V. I was going to compare them with the KongPower 11.1V 2200mAh packs also in series, but I forgot to turn off my rx pack and I drained it, but I'll run it tomorrow.
lutach
lutach's Avatar
09.23.2007, 02:30 PM
Some pictures of the set up.
ID:	3275   Click image for larger version
ID:	3276   Click image for larger version
lutach
lutach's Avatar
09.23.2007, 02:31 PM
Some more.
ID:	3278   Click image for larger version
