09.24.2007, 01:43 AM
I am in the process of converting an Aftershock at the moment. I will be using the emaxx tranny with a custom mount and battery tray. I have settled on using either a 9xl or a KB 45mm 8xl. Both have around a 1800kv rating so I will be running 5s lipo. A quark 125 will be hadling the esc duty, as it is the only higher amp esc I have that can handle 5s. I will gear for about 38mph in second gear, and retain 1st as it will be more bash-friendly in some of my play areas. I doubt that the current HV wil handle this truck, gearing will have to be low to make up for the lack of torque. With the nitro gear removed the truck is not too heavy, but add all of the brushless stuff and batteries and it get heavy fast.
