damon
09.25.2007, 03:43 PM
I did take the Airtronic MX3 redio off and put the original traxxas one on and it performed the same. I did not check the controller or motor temp being it only ran for 1-2 minutes. Is there a way to check the motor to see if it is bad? Is it unlikely to be the controller? I will put it back together, recallibrate the radio and check the EPA. Then I will check the temp. Any further suggestions? Thank you all!
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
09.25.2007, 03:46 PM
Maybe try doing a free wheel test first... 70% thottle for a couple minutes to see how things go, check temps, then report back. Okay?
Also, do you have any other controllers that you could test it with?
damon
09.25.2007, 04:05 PM
Great advice. No other controller, just the 12020. I will put it together and do the 70% throttle test, take a temp and report back.
