rchippie
rchippie's Avatar
09.28.2007, 12:42 PM
Do you have any servos hooked up when you program it? I ask this because if there is an issue with a servo and it is pulling too much current for the UBEC to handle, the UBEC may be causing the receiver to malfunction. A receiver pack has more current capability. If that's not it, try a capacitor on the UBEC output to help eliminate any noise. I assume you disable the built-in BEC when using an external BEC or Rx pack?
yes i pulled the black bec jumper. Yes i have the steering servo hooked up. Maybe i popped the UBEC. I dont have any caps to put on it. If i have to run a reciver pack it's no big deal. Im going to buy a new controller any way.
REAL MEN RUN BRUSHLESS
rchippie
rchippie's Avatar
10.13.2007, 06:23 PM
I ran my converted X1cr last night, & it got real hot & thermaled. My ? is sinice there are no moving parts on it, what is everyone's opinion on removing the heatshrink to help it get some air to help cool it ?. Also i noticed when it gets hot just before thermal when brake is applied it goes in to reverse even thou the reverse is disabled.
