Thread Tools Rating: Thread Rating: 4 votes, 4.00 average. Display Modes
Finnster
KillaHurtz
Finnster's Avatar
09.28.2007, 05:56 PM
Originally Posted by wallot View Post
hyperion is very friendly to use.
dont forget to get A123 version of the lba10. the standard version works but you wont see individual cell values through the data cable on hyperion charger
I was looking at the one @ b-p-p. It says its A123s ready, but the downloadable manual does not mention it, so I could tell much.
othello
HV basher
09.28.2007, 07:28 PM
I am using the hyperion 1210 with my 2 5s1p A123 connected in series. With 10s A123 the charger starts at 5,4A and finishes at 4.4A. A full charge takes around 32 minutes (without balancer). The more the cells are out of balance the longer it takes (even witout balancer).
But the hyperion 1210 also starts slowly when the cells are below 29-30V. Therefore i charge 1 minute in 9s mode @ 5A and then switch to 10s mode.
Although A123 cells do remain quite good in balance, they are not perfect and do start to drift in voltage. I too now will buy a lba10 or a Astro blinky for A123. Balancing during every charge cycle is not necessary. So one balancer should suffice.
As of april 2007 the LBA10 "net" balancer is compatible with A123 cells.
Finnster
KillaHurtz
Finnster's Avatar
09.28.2007, 10:00 PM
Hmm good info. Too bad to hear about the slow start tho, but 1 min of 9S isn't too bad. w/ my 5S2p A123 batt, 4S A123 is too low, and even 4S lipo just goes to cv mode quickly. Way too much fiddling needed when these cells are uber safe. I do have a blinky FWIW, tho I rarely use it. The cells go out on full charge, but then even off after a bit
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
09.28.2007, 11:57 PM
In time I would like to convert my 7s2p pack to 14s pack... oh what motor/esc to use?!
The only time I have ever used 'balancing' was some PC ATX connectors (check my pics), but they were never out of balance... plus it was a little time consuming doing each cell individually, as I had no balancer, just the taps and my trusty BK prog. power supply.
We should have a STICKY THREAD on A123 cells... sources (A123 racing, dewalt packs, etc), benefits (safety, life, lower cost, especially over lifetime), balancing , and what not. That would be very useful, IMO.
grenade6
09.30.2007, 11:23 PM
hey you might already know about this charged but this is the one i have. http://www.rcaccessory.com/index.asp...ROD&ProdID=203
its my first charger other then the ones that just charge the transmiter battery so i cant really tell you lots about it other then i havent blown up any batteries yet lol. but it does have a 8 cell balancer for the a123 battery and it can charge them. im waiting for my batteries to show up (ordered them 2 weeks ago) so i cant even tell you how well it charges them lol.
